The Reference Marker tool displays the drawing number and sheet number of the referenced drawing. Select from a variety of configurations.
To create a reference marker:
1. Ensure that the appropriate layer is active.
2. Click the Reference Marker tool from the Dims/Notes tool set.
3. Click on the drawing at the desired location to place a reference marker object.
4. Click again to set the rotation.
If this is the first time the object is inserted in this session, the Object Properties dialog box opens. These parameters apply to subsequent placements of the object and can be changed in the Object Info palette. Click OK.
Reference marker objects maintain a constant size regardless of the drawing scale.
5. Set the line attributes as needed using the Attributes palette.
