 Revision
 Marker
Revision
 Marker The Revision Marker tool displays the drawing revision number.
To place a revision marker object:
1. Click the Revision Marker tool from the Dims/Notes tool set.
2. Click on the drawing at the desired location to place a revision marker object.
3. Click again to set the rotation.
If this is the first time the object is inserted in this session, the Object Properties dialog box opens. These parameters apply to subsequent placements of the object and can be changed in the Object Info palette. Click OK.
Revision marker objects maintain a constant size regardless of the drawing scale.
