Creating Slab ComponentsSlab components define the sections that make up a slab. For example, to indicate that a slab is made up of gypsum board ceiling, wood framing, and a plywood deck, define a component for each of these items to illustrate their location. Slab components can be offset from the edges of the walls (automatically bounded slabs) or the edge of the slab (manual slabs); their appearance can be specified for cross-section views, and they can be textured (Renderworks required), creating realistic section views and rendered views, as well as accurate slab material estimates. The area and volume of slab components (minus any holes cut) can be calculated in worksheets; see Worksheet Functions).
The overall thickness of a slab is equal to the sum of its components. Component fill and pen style are only displayed in section viewports.
To define slab components prior to drawing the slab:
1. Click the Slab tool from the Building Shell tool set, and click Preferences from the Tool bar.
The Slab Preferences dialog box opens.
2. On the Definition tab, click New.
The Slab Component Settings dialog box opens. Specify the component name, thickness, edge offset, and appearance in section views and rendered views.
3. Click OK to create the component and return to the Slab Preferences dialog box.
The slab’s Overall Thickness value changes to be determined by its components. As components are defined, they display in the preview. Click and drag a component in the # column to change its order.
4. To save the component settings with the slab settings as a slab style, click Save Preferences as Slab Style.
5. Click OK.
Once created, the components of a selected slab can be edited by clicking Components from the Object Info palette.
To define or edit slab components for an existing, unstyled slab:
1. Select the slab(s).
2. From the Object Info palette, click Components.
The Components dialog box opens.
3. Click New or Edit, and define or edit the components as described in Creating Slab Components.
4. Click OK to return to the Components dialog box.
5. Click OK. The new component definition is applied to the selected slab(s).
