Render TabWhen the Renderworks product is installed, this tab is available for the assigning and mapping of textures to 3D objects (see Applying a Texture to an Object for a complete description of the parameters available on the Render tab). In two cases, parameters on the Render tab are available in Vectorworks Design Series products, even if Renderworks is not installed: if sketch rendering is active, the Sketch parameter is available, and mesh objects rendered in OpenGL can be smoothed using the Mesh Smoothing parameter.
