The Add Solids command joins two or more 3D objects into a single model.
To add solids in 3D:
1. Select two or more 3D objects to combine.
2. Select Model > Add Solids.
A single solid model is created from the objects.
Editing 3D Object Surfaces
Editing 2D Object Surfaces
www.vectorworks.net
