Even Divide
The Even Divide command divides lines, arcs, circles, and rectangles into the specified number of subdivisions. You can choose whether or not to retain the original object.
To evenly divide lines, arcs, circles, and rectangles:
1. Select one or more objects to divide.
2. Select Modify > Drafting Aids > Even Divide.
The Even Divide dialog box opens.
3. Set the parameters and click OK to create new objects that are even subdivisions of the selected object(s).
Arc into Segments
Line into Segments
Create Dividing Lines
Simplifying Polygons and Polylines
www.vectorworks.net
