The Scale Objects command rescales the X and/or Y dimension of any selected solid, object, or group, or rescales the selected items uniformly in the X,Y, and Z dimensions. The selected item is rescaled using its center point. The object can be rescaled by indicating a segment on the drawing and entering a new distance for the segment. If no objects are selected, the entire drawing can be scaled. Layer links cannot be scaled with this command.
Unless you are scaling the entire drawing, the Scale Objects command does not scale symbols directly, although it can scale symbols in object editing mode. Use the Object Info palette or the Selection tool to scale a symbol instance directly in the drawing, as described in Scaling Symbols from the Object Info Palette.
To scale objects:
1. Select the object(s) to scale.
If no objects are selected, all objects on all layers of the drawing are scaled.
2. Select Modify > Scale Objects.
The Scale Objects dialog box opens. Specify the scaling method and parameters.
3. If specifying the scale factor with the Symmetric by Distance option, click the button to switch temporarily to the drawing. Click to indicate the start of the segment, move the mouse, and click to indicate the end of the segment. You are returned to the Scale Objects dialog box, and the Current Distance value has been specified. Enter the New Distance for the segment.
4. Click OK.
Solids can be scaled asymmetrically, through both the Scale Objects command (see Scaling Objects) and the Object Info palette. The internal components of the solid do not change, and the solid can still be edited after the scaling operation. Spheres, hemispheres, and cones cannot be scaled asymmetrically.
In the Object Info palette, enter a scale factor in the X Scale, Y Scale, or Z Scale field to scale the selected solid along the specified axis.
A selected solid can also be scaled asymmetrically by selecting the Modify > Scale Objects command and entering an Asymmetric scale factor. However, the current view must be aligned with the solid’s matrix for scaling to occur.
Symbol instances placed in the drawing can be scaled from the Object Info palette; this is an advantage because different sizes of the same symbol do not require a new symbol for each size.
Symbols can also be scaled interactively with the interactive scaling mode of the Selection tool. See The Selection Tool.
To scale a symbol instance:
1. Select the symbol instance in the drawing area.
2. From the Object Info palette, select Symmetric or Asymmetric Scaling.
3. For Symmetric scaling, enter the scale Factor. For Asymmetric scaling, enter the scaling factor along the specified axis.
Page-based symbols can only be scaled symmetrically.
4. The symbol is resized. The Object Info palette displays Scaled at the top of the Shape pane for symbols that have been scaled. Other instances of the same symbol in the drawing remain unscaled.
