Use the Trim command to trim lines or walls where they intersect with another object.
To trim objects:
1. If necessary, position the trimming object over the object(s) to be trimmed.
2. Select the trimming object.
3. Select Modify > Trim.
4. Click on the object to be trimmed.
The trim command is executed and the pieces can be moved independently.
