Editing Curtain Wall Panels
To select and manipulate curtain wall panels:
1. Click the Edit Curtain Wall tool from the Building Shell tool set, and click Select Panel mode from the Tool bar.
2. Select the curtain wall to edit.
3. Select the panel or panels to edit. Panels cannot be moved; the position of the panels is determined by the frames. Selecting panels is very similar to selecting frames; see Editing Curtain Wall Frames.
4. The settings of selected panels can be edited by clicking the Settings mode from the Tool bar.
Alternatively, right-click (Windows) or Ctrl-click (Mac) on the frame and select Edit Panels from the context menu.
When one or more curtain wall panels are selected, a door or window can be easily inserted. Right-click (Windows) or Ctrl-click (Mac) on the panel and select Insert Window or Insert Door from the context menu. The window or door is automatically inserted as a curtain wall window or door, and sized to fit within the selected panel or panels.
