X Join mode joins two wall segments at the point where they intersect. Because neither wall segment’s length is altered, the two segments must already intersect in order to use this mode.
To join walls with the X Join mode:
1. Click the Wall Join tool from the appropriate tool set:
● Fundamentals workspace: Walls tool set
● Design Series workspaces: Building Shell tool set
Alternatively, right-click (Windows) or Ctrl-click (Mac) on the wall and select Join from the context menu.
2. Click X Join from the Tool bar.
3. Select the wall segment to become non-load bearing.
4. Select the wall segment to become load bearing.
The first wall segment selected is split into two walls segments, which are joined to the load bearing wall.
