To create a detail bubble:
Click the Detail Bubble tool from the Dims/Notes tool set.
Click to place the object in the drawing, and click again to set the length and rotation of the leader line.
If no Part Info record exists, one is created automatically the first time a detail bubble is placed in the drawing.
The detail bubble number automatically increments as the bubbles are placed. Change the auto-incrementing number by editing the Item Number field from the Object Info palette. When detail bubble placement resumes, the last number entered becomes the starting number.
