Use the Reference Marker tool to indicate the drawing number and sheet number of a referenced drawing, in a variety of configurations.
Reference markers maintain a constant size regardless of the drawing scale.
To create a reference marker:
Click the Reference Marker tool from the Dims/Notes tool set.
Click to place the object in the drawing, and click again to set the rotation.
