Use the Scale Bar tool to indicate the scale of the drawing objects. To include a scale bar for a viewport, select Modify > Edit Viewport, and place the scale bar as a viewport annotation.
To create a scale bar:
Click the Scale Bar tool from the Dims/Notes tool set.
Click to place the object in the drawing, and click again to set the rotation.
