When snap to object is on, the SmartCursor finds specific parts of an object, such as corners, endpoints, midpoints, or centers of 2D objects and arc edges, as well as meshes, extrudes, sweeps, spheres, 3D polygons, 3D planar faces, and walls, floors, roofs, roof faces, loci, and columns. Cues display near the cursor to identify the location.
To set object snapping:
Select Tools > SmartCursor Settings, or double-click the Snap to Object tool in the Snapping palette.
The SmartCursor Settings dialog box opens. From the Object tab, specify the object snap settings.
Click OK to set the object snapping options.
To activate object snapping, click the Snap to Object tool from the Snapping palette.
Click here for a video tip about this topic (Internet access required).
