DesignSeries00009.pngObject Database Connection
The final step in setting up a database connection is to connect object instances to the database. The procedure differs depending on whether one or multiple objects are selected for connection.
    Single Object Connection
    Multiple Object Connection
Once connected, the connection can be edited. The connection can also be removed.
Editing Object Connections
Removing Object Connections
Database Setup
Database Connection
vectorworks.net
