Compression Springs 1
and 2
To insert a compression spring 1:
To insert a compression spring 2:
Click the Compression Spring 1 or Compression Spring 2 tool from the Machine Components tool set.
Click to place the object in the drawing, and click again to set the rotation.
A utility calculates spring rates for compression springs (see Spring Calculator).
To simulate the appearance of a spring wound around an object (such as a shaft or screw), use two springs. Set the front spring’s display parameter to Solid - Front Coils Only. The spring behind the object is set to Solid - Rear Coils Only. Adjust the objects’ relative position with the Modify > Send > Send to Front and Modify > Send > Send to Rear commands until the object displays correctly.
