DesignSeries00356.pngDie Springs
Die springs are made of rectangular wire.
To insert a die spring:
  1. Click the Die Spring tool from the Machine Components tool set.
  2. Click to place the object in the drawing, and click again to set the rotation.
vectorworks.net
