DesignSeries00297.pngFlanged Bearings: 4 Hole
To insert a flanged bearing - 4 hole:
  1. Click the Flanged Bearing - 4 Hole tool from the Machine Components tool set.
  2. Click to place the object in the drawing, and click again to set the rotation.
Flanged Bearings: 2 Hole
vectorworks.net
