Torsion Springs: End View
and 3D
To insert a torsion spring - end view:
Click the Torsion Spring - End View tool or the Torsion Spring - 3D tool from the Machine Components tool set.
Click to place the object in the drawing, and click again to set the rotation.
In the Object Info palette, set the torsion spring properties (Wire Diameter, Outside Diameter, and Spiral), and then set the properties for each end of the spring.
