Diametrical Dimensioning Inside Circle/Arc
The Internal Diametrical mode measures and dimensions the diameter of a circle or arc, and places the dimension inside the object.
To create a diameter dimension inside a circle or arc:
  1. Click the Radial Dimension tool from the appropriate tool set/palette, and select Internal Diametrical mode.
  2. ●    All workspaces: Dims/Notes tool set
    ●    Spotlight and Landmark workspaces: Basic tool palette
  3. From the Tool bar, select a Dim Std (dimension standard).
  4. Click on or within the arc or circle to dimension.
  5. Move the cursor to preview the dimension line location.
  6. Click to place the dimension.
Radial Dimensioning
Editing Dimensions
vectorworks.net
