DesignSeries00037.pngEditing Slab Geometry with 3D Modifiers
A slab can be modified by a 3D shape, such as an extrude, tapered extrude, extrude along path, sweep, solid, or closed mesh. These modifications allow a slab to have a ramp, add support beams, or include drainage features. The boundaries of the modifier can be specifically defined according to its shape, or they can simply be defined by the slab boundary.
Create a solid section from a grade object as described in Creating a Solid Section from Grade Objects, and use the resulting sloping solid as a 3D modifier.
Adding a 3D Object to a Slab
To add a 3D object to a slab:
  1. Select both the slab and the 3D modifier.
  2. Select the Add 3D Object To Slab command from the appropriate menu:
  3.     Architect workspace: AEC > Add 3D Object To Slab
        Landmark workspace: Landmark > Architectural > Add 3D Object To Slab
        Spotlight workspace: Spotlight > Architectural > Add 3D Object To Slab
    The Add 3D Object to Slab dialog box opens.
  4. Click OK.
Subtracting a 3D Object from a Slab
To subtract a 3D object from a slab:
  2. Select Subtract 3D Object From Slab.
    Architect workspace: AEC > Subtract 3D Object From Slab
    Landmark workspace: Landmark > Architectural > Subtract 3D Object From Slab
    Spotlight workspace: Spotlight > Architectural > Subtract 3D Object From Slab
The 3D geometry is subtracted from every component that it overlaps.
Changing the Slab Modifier
Editing Slab Geometry with 2D Modifiers
vectorworks.net
