Setting the High Hook HeightThe high hook height of selected hoists can be automatically set to the height of a clicked point. Only selected hoist objects are adjusted by this command (no other drawing objects can be selected).
To set the high hook height of selected hoists:
Switch to a side 3D view, like Left, Right, or Front, that shows the hoists.
Select the hoists to adjust.
Select Spotlight > Hoists > Set Selected High Hook Height.
Click on the reference object, such as the bottom of a support structure, or another hoist. The selected object is highlighted.
The hoists are set to the adjusted High Hook Height.
