Exporting in KML FormatThe Export KML command exports 3D drawing components to KML, the markup language used by the Google Earth application. The resulting file can then be opened in Google Earth, in order to provide a visualization of how a building fits into its intended environment, for example. KML models can also be uploaded and shared through the Trimble ® 3D Warehouse.
To export a KML file:
Select File > Export > Export KML (3D only).
The KML Export Options dialog box opens.
Select the export parameters, and then click OK.
Specify the export file name and destination, and then click Save.
