A generic drip emitter can be inserted into the drawing with the Drip Emitter tool. Alternatively, use a drip emitter from one of the irrigation object libraries.
To insert a drip emitter:
Click the Drip Emitter tool from the Site Planning tool set.
Click to place the object in the drawing, and click again to set the rotation.
