An irrigation line can be inserted into the drawing with the Irrigation Line tool. Alternatively, use an irrigation line from one of the irrigation object libraries.
To insert an irrigation line:
Click the Irrigation Line tool from the Site Planning tool set.
Click to place the object in the drawing, and click again to set the length and rotation.
