The Show or Hide Spray Pattern command controls the visibility of the spray pattern of irrigation head objects.
To show or hide the spray pattern:
Select View > Show > Show or Hide Spray Pattern.
If the spray patterns are currently hidden, this command causes the spray pattern of all irrigation head objects to become visible. In the Object Info palette, Show Spray Pattern is selected automatically.
If the spray patterns are currently visible, this command causes the spray pattern of all irrigation head objects to become hidden. In the Object Info palette, Show Spray Pattern is automatically deselected.
