Spot00061.pngInserting Speakers
Use the Speaker tool to insert individual speakers that are not part of an array. Manually-inserted speakers can be placed as single speakers, or as several speakers arranged in a column. A variety of supports and labeling options are available. Use a speaker type with pre-set data from the speaker library file that is included with the Vectorworks Spotlight product (in the Vectorworks application folder [Vectorworks]\Libraries). You can also create a speaker with custom data and save it to the library for future use and sharing.
To insert a speaker:
  1. Click the Speaker tool from the Spotlight tool set.
  2. Click to place the object in the drawing, and click again to set the rotation.
Inserting Speakers and Speaker Arrays
Formatting Speaker Object Labels
Inserting Speaker Arrays
vectorworks.net
