Spot00074.pngInserting a Stage Lift
A stage lift object can be added to a drawing to represent the typical adjustable support device commonly found on stage for supporting speakers, trusses, and other stage equipment. The stage lift can be shown extended or collapsed, with a specific appearance and fork position, and can be labeled.
To insert a stage lift:
  1. Click the Stage Lift tool from the Spotlight tool set.
  2. Click to place the object in the drawing, and click again to set the rotation.
Formatting Stage Lift Labels
vectorworks.net
