Inserting
Communication DevicesThe Comm Device tool inserts an indicator and basic specifications to indicate the type and location of a communication device.
To insert a communications device:
Click the Comm Device tool from the MEP tool set.
Click to place the object, and click again to set the rotation. If the object is inserted in a wall, its direction can be changed later by clicking Flip from the Object Info palette.
