3D Custom Rotation
The precision of the rotation values that can be entered (degrees, minutes, and/or seconds) depends on the Units setting.
To rotate at custom angles in 3D:
  1. Select the 3D object or objects to rotate.
  2. Select Modify > Rotate > Rotate 3D.
  3. The Rotate Object in 3D dialog box opens. Specify the rotation parameters.
  4. Click OK.
Rotating Objects
vectorworks.net
