The center of rotation for this command is limited to the center of the object’s bounding box. The rotation is performed within the screen plane.
To rotate by a custom angle:
Select the object or objects to rotate.
Select Modify > Rotate > Rotate. Alternatively, double-click the Rotate tool.
The Rotate Object dialog box opens.
Enter the rotation angle.
The precision of the values that can be entered (degrees, minutes, and/or seconds) depends on the Units setting.
Click OK.
