The rotate commands provide a number of ways to rotate objects in the screen plane without changing their base location in the drawing. Select one of the preset rotation angles, or specify a custom rotation angle.
To rotate at a specified angle:
Select the object to rotate.
Select Modify > Rotate, and then the pre-set rotation.
Alternatively, right-click (Windows) or Ctrl-click (Mac) on the object, and select Rotate from the object context menu.
