Reshaping Polylines
Polylines can be reshaped in a manner that is similar to an Edit Group operation. The polyline itself is locked in this process, but holes can be added to it, filleted, chamfered, offset, duplicated, extracted, and deleted from it.
To reshape a polyline:
  1. Select the polyline to change.
  2. Select Modify > Edit Polyline.
  3. Select polyline holes and move, delete, or reshape them. Add new holes to the polyline, or move a hole out of the polyline to extract it, creating individual polylines.
  4. The original polyline is locked and cannot be edited.
  5. Click Exit Polyline to return to the drawing.
Reshaping Objects
Editing Vertex-Based Objects
Smoothing Objects
Converting Polyline Vertices from Arc to Radius
vectorworks.net
