Reshaping Objects with the Freehand Tool
A polyline, polygon, rectangle, circle, or arc can be reshaped using the Freehand Edit mode of the Freehand tool. The direction of the curve drawn determines the new object shape. An edited object is converted to a polyline after editing is complete.
To reshape objects using the Freehand tool:
  1. Select a valid object.
  2. Click the Freehand tool from the Basic palette.
  3. Click Freehand Edit mode from the Tool bar.
  4. Click to draw the new curve, editing the valid object using the following curve direction guidelines:
  5. Action
    Guidelines
    Change existing curve
    Connect two points with new curve
    Create closure with new curve
    Add a new curve to an existing curve
    Extend existing curve
    Retain partial curve
  6. Click again to finish drawing the freehand polyline edit. The valid object is edited and converted to a polyline.
Polyline Tool
Reshaping Objects
Closing and Opening Polygons and Polylines
Displaying and Reversing Object Direction
vectorworks.net
