Stitching and Trimming Surfaces
The Stitch and Trim Surfaces command creates a generic solid from several intersecting surfaces (including NURBS surfaces or solids such as extrudes or sweeps).
This command may not be able to manipulate certain types of surface geometry. See Surface Geometry Requirements.
To stitch and trim intersecting surfaces:
  1. Select the intersecting surfaces.
    The surfaces must enclose a volume.
  3. Select Model > 3D Power Pack > Stitch and Trim Surfaces.
The surfaces enclosing the volume are stitched together and then trimmed, resulting in a generic solid.
Selecting the Edges and Faces of a Solid
NURBS Curves and Surfaces
vectorworks.net
