Land00049.pngCorrecting Site Modifier Errors
If site modifier errors are detected when the site model is updated, an icon displays at the location of each error.
The following modifier problems can generate errors:
    Pad which does not lie inside the grade limits
    Pad intersecting grade limits or the site border
    Two intersecting pads
    Spoil pile intersecting the site border
    Spoil pile intersecting grade limits or the site border
    Two intersecting spoil piles
    Texture bed intersecting the site border
    Two intersecting texture beds
    Locus which does not lie inside the grade limits
If these errors exist, the site model can still be modified; however, results may not be as expected. It may be better to resolve the errors and update the site model again before proceeding.
When the site model object is selected, the Object Info palette’s Error Count field displays the number of errors, and an icon displays at the location of each error. Hold the cursor over an icon to display a SmartCursor cue that describes the error. Resolve the errors by making adjustments to prevent all intersecting modifiers.
To hide the icons from view (but not resolve the underlying errors), deselect Show Errors from the Object Info palette.
Update the site model to ensure that all errors have been corrected.
Validating 3D Source Data
Site Model Properties
vectorworks.net
