Edit property lines by using the Reshape tool, or by clicking the Edit with Dialog button from the Object Info palette. Additional parameters can also be modified from the Object Info palette. See Reshaping Objects for information on using the Reshape tool for editing.
To edit property lines using the Object Info palette:
Select the property line.
Modify the parameters from the Object Info palette.
For information on editing object vertices, see Reshaping Objects.
If the property line is designated to be a texture bed on the site model, select Tools > Organization. On the Classes tab, select the class designated as the texture bed class, and assign it a distinctive fill color, or, if the Renderworks product is installed, a texture. Select the site model and click Update from the Object Info palette; the property line displays as a texture bed on the site model. Switch to a 3D view and render for the full effect.
When Annotate Segments is selected and curve data exists, a curve data worksheet is automatically created, showing curve data in worksheet form. Select Window > Worksheets to display the worksheet, or view it from the Resource Browser.
