ArchLand00029.pngInserting Handrails
Handrails can be inserted independently of those available as part of the Stair tool.
To insert a straight handrail:
To insert a curved handrail:
  1. Select either the Straight Handrail tool or Curved Handrail tool from the Furn/Fixtures tool set.
  2. Click to place the object in the drawing, and click again to set the rotation.
Stair Settings: Railings Tab
vectorworks.net
