Resetting Plug-in Objects from Previous VersionsWhen you migrate plug-in objects from previous versions, some Object Info palette parameters display when they should be hidden. Select the Reset All Plug-ins command to update the Object Info palette parameter display.
To reset plug-in objects:
Open an older drawing containing plug-in objects.
Select Tools > Utilities > Reset All Plug-ins.
The Reset All Plug-ins dialog box opens.
Click Yes to reset plug-in objects.
A message displays the update status. When complete, the Object Info palette displays only the pertinent parameters.
