Specifies the rafter size in width
x height, in current file units. Sizes can be edited by
selecting Edit List (see Custom Frame Element Sizes).
Dormer Rafter Size
If the roof contains dormer windows,
enter the size, in Width x Height, of the dormer rafters
Minimum Spacing
Specifies the minimum distance allowed
between rafters
Maximum Spacing
Specifies the maximum distance allowed
between rafters; for consistent rafter spacing of the
entire roof, the Minimum and
MaximumSpacing
values should be equal
Set top of Rafters to
Top of Roof object/component
Matches the tops of the rafters to
the top of the roof object, or to the top of the component
selected in Use Roof Components
Bottom of Roof object/component
Treats the roof object as a roof
deck and matches the tops of the rafters to the bottom
of the roof, or to the bottom of the component selected
Match Rafters across Ridges/Hips/Valleys
Select to ensure that opposing rafters
meet on the roof ridges, hips, and valleys
Class
To control appearance and visibility,
select a class from the list of classes present in the
drawing or create a new class (see Creating Classes)
