To save the current drawing area view:
Select View > Save View.
Alternatively, from the Organization dialog box, click the Saved Views tab, and then click the New button. If Vectorworks Design Series is installed, from the Navigation palette, click the Saved Views tab, and then select the New command from the navigation menu.
The Save View dialog box opens.
Specify the view options, the active layer and class, and the visibilities of layers and classes.
Click OK to save the view with the specified settings. The saved view is then available from the Saved Views menu and from the Organization dialog box.
