Arch00033.pngStandard Viewports
The Create Standard Viewports command creates standards-compliant viewports and their associated sheet layers, with the layer and class visibilities of a standard drawing. See Creating Sheet Layer Viewports.
If desired, views corresponding to the viewports can also be created. This allows easy navigation through the different drawing views (with set layer and class visibilities) during the design process.
Viewports are created in five categories. The available viewport types are:
    Site Plan Drawings
    Project Plan Drawings
    Floor Plan Drawings
    Auxiliary Plan Drawings
    Notation Drawings
Select the Create Standard Viewports command again to make changes to the project settings at any time. The column on the right shows the current viewports when the command is run again.
Setting Standard Viewport Preferences
Creating Standard Viewports
vectorworks.net
