The Create Symbol command creates symbols from 2D and/or 3D objects, including text. Symbols can also be created from other symbols, from plug-in objects, groups, and worksheets. At placement, the symbol can convert automatically into a group or plug-in object. Viewports cannot be made into symbols.
For more information on symbol types and color categories, see Symbol Types.
Item |
Convert to |
Result |
2D screen object |
2D symbol |
2D black symbol, planar |
3D object and/or 2D planar |
3D symbol |
3D black symbol, for use in a 3D view only |
2D screen + 3D object |
Hybrid symbol |
Hybrid black symbol, for use in 2D plan and 3D models |
Symbol |
Symbol |
Saves any changes to the current symbol attributes as a new, black symbol definition |
Group |
Creates a new blue symbol definition, to be inserted as a group |
Plug-in object |
Creates a new red symbol definition, to be inserted as a plug-in object |
Group |
Symbol |
Creates a new black symbol definition, with multiple objects existing within a symbol container |
Plug-in object |
Symbol |
Creates a new black symbol definition. This allows all instances to change by editing the plug-in object inside the symbol, even though the actual symbol instance cannot be edited. |
Plug-in object |
Creates a new red symbol definition, to be inserted as a plug-in object. This allows an editable plug-in object to be placed in a drawing with saved parameters. For example, a door plug-in object, when saved with a width of 4’ and inserted as a plug-in object, is inserted with a width of 4’ rather than with the default width. |
Worksheet |
Group |
Creates a new blue symbol definition, to be inserted as a group. For example, a worksheet can be saved as a preformatted report by saving it as a blue symbol definition. |
To create a new symbol:
Select the object to convert into a symbol.
To create a hybrid symbol, select both the 2D and 3D objects, which become the 2D and 3D components of the symbol. In Top/Plan view, align the objects first (symbol alignment can be adjusted after creation with the Edit Symbol command). The symbol preview that displays in the Resource Browser is generated in the symbol view at creation or editing.
If a hybrid symbol will be inserted into a wall, you can optionally specify the 3D wall hole component in addition to the 2D and 3D components; see Adding a 3D Wall Hole Component to a Symbol Definition.
For 2D symbols inserted in walls, two loci can be specified as wall break locations. In Top/Plan view, place two loci at opposing locations with the object to convert, and select them all before converting. When the symbol is inserted into the wall, the wall breaks at the loci locations instead of the symbol bounding box.
Select Modify > Create Symbol.
The Create Symbol dialog box opens.
Click OK.
If the Next Mouse Click insertion point option is selected, click to specify the desired symbol insertion point.
Specify the folder location for the new symbol in the next Create Symbol dialog box.
Click the folder to select it as the destination for the new symbol.
Click OK.
The new symbol is added to the Resource Browser.
