This command detaches the selected record formats from all symbol definitions in a selected symbol folder.
To detach a record:
Select Tools > Records > Detach Record.
The Detach Record dialog box opens.
From the Symbol Folder list, select None, All, or a symbol folder, if any.
Select None to detach the record from the symbol definition at the root of the symbol library (symbol definitions not in any folder). Select All to detach the record format from all of the symbol definition in the file’s symbol library. Selecting a symbol folder changes all of the symbol definitions only in that folder and any subfolders.
From the Record Format list, select one of the record formats defined in the current file to detach from the symbol library.
Click OK.
Confirm the operation and the number of symbol definitions affected.
