 Modifying Objects by
 Record Value
 Record ValueThis command modifies the color, size, or height of objects in a drawing based on the numeric value of a particular record field attached to the selected items. This can be useful for analyzing and comparing objects in a drawing.
To modify objects by record value:
Select Tools > Records > Modify by Record.
The Modify by Record Value dialog box opens.
Click OK.
The color, size, or height of the drawing objects are modified.
If you have saved settings to use with the Modify by Record command, use the Manage button on the Modify by Record Value dialog box to rename or delete these saved settings when needed.
To manage saved settings for the Modify by Record command:
Click Manage.
The Manage Saved Sets dialog box opens. Select the set to change.
Click OK to close the Manage Saved Sets dialog box. Click OK again to close the Modify by Record Value dialog box.
