Walls can be created from a polygon in the Vectorworks Fundamentals product.
In the Vectorworks Design Series products, walls can be created by drawing a polyline or shape and then selecting the Create Objects from Shapes command (see Creating Objects from Shapes).
To create walls from a polygon:
Draw or select the polygon to become the basis for the walls.
Select Modify > Create Walls from Polygon.
The Create Walls from Poly dialog box opens. Select the desired wall parameters.
Click OK.
The walls are created based on the original polygon and the specified parameters.
