Setting
Curtain Wall Frame ParametersThe frame settings and appearance are controlled individually for each frame location, for maximum flexibility when setting the frame parameters.
Unstyled curtain walls can be drawn first, and the curtain wall parameters can be set later from the Object Info palette by clicking Curtain Wall Grid. The Curtain Wall Grid dialog box opens, to edit the parameters of the unstyled curtain wall. However, editing unstyled walls by this method may clear existing frames and panels, and recreate the curtain wall grid.
To set the curtain wall frame appearance:
From the Definition tab of the Wall Preferences dialog box, or when editing a curtain wall style, click Frame Settings.
The Frame Settings dialog box opens.
Click OK.
The parameters can be edited from the Object Info palette; see Wall Properties. The Cut Plane parameter determines the height for displaying the curtain wall in Top/Plan view.
