Capped Join ModeLike the T Join mode, the Capped Join mode extends or shortens one wall component until it intersects with a second component. The component end is capped at the point where it joins the other wall.
To join wall components with the Capped Join mode:
Click the Component Join tool from the Building Shell tool set.
Click Capped Join from the Tool bar.
Select the component within the wall segment to join.
Select the second wall segment to join. The component to be joined is highlighted.
Repeat steps 3 and 4 for each component within the wall segment that needs to be joined.
