Creating Columns and Pilasters
The Vectorworks Fundamentals product and all Vectorworks Design Series products include a basic architectural column object (for aesthetic and space-defining purposes). In the Architect product, the column object offers additional structural capabilities, and a pilaster object is provided.
In the Vectorworks Architect product, columns and pilasters can be architectural in nature, structural in nature, or both. Use the Column tool or Pilaster tool to draw an object that not only reflects the architectural appearance of a column/pilaster, but also defines it in structural terms that can be used in an engineering analysis of the building. Structural and architectural elements can be displayed or hidden. The column ID can also, optionally, be placed on the drawing. Additionally, in the Architect product, the column/pilaster can be exported to IFC format for exchange with structural analysis programs.
A pilaster can be placed in a wall (however, a column cannot be placed in a wall). A pilaster inserted in a wall can set its architectural height relative to the wall.
Tool access varies depending on the Vectorworks product installed:
Vectorworks Product
Tool Set / Tool
Fundamentals
Walls > Column (basic column)
Architect and Designer
Building Shell > Column (architectural column with additional capabilities)
Building Shell > Pilaster
Landmark and Spotlight
Building Shell > Column (basic column)
To create a column:
To create a pilaster:
  1. Click the Column tool or the Pilaster tool from the appropriate tool set:
  2. ●    Fundamentals workspace: Walls tool set
    ●    Design Series workspaces: Building Shell tool set
  3. Click to place the object in the drawing, and click again to set the rotation.
To create a circular or square shaft, capital, or base, enter the same value for the width and depth.
Basic Column Parameters
The basic column object is available with the Vectorworks Fundamentals, Landmark, and Spotlight products.
Arch.pngArchitect Column and Pilaster Parameters
The architectural column and pilaster objects are available with the Vectorworks Architect and Designer products.
Exporting Columns and Pilasters to IFC Format
vectorworks.net
