Setting Visibility with Class and Design Layer Options
The Class Options and Layer Options commands control how all the classes or design layers in a drawing display. For example, a drawing project can be set to display only the active class, temporarily hiding all objects assigned to other classes.
To change the options for displaying, snapping to, and editing objects in the current class or design layer:
  1. Select View > Class Options (or Layer Options) and then the option.
  2. Alternatively, right-click (Windows) or Ctrl-click (Mac) in the drawing area and select Class Options or Layer Options from the document context menu.
    Command
    Description
    Active Only
    Displays only objects in the active class/layer; only the active class/layer prints
    Gray Others
    Displays the active class/layer normally and all other classes/layers appear dimmed (except for those set to invisible); even though visible, objects in dimmed classes/layers cannot be edited
    Gray/Snap Others
    Displays the active class/layer normally and all other classes/layers appear dimmed (except for those set to invisible); objects in any normally displayed or gray class/layer can be snapped to. Only objects in the active class/layer can be edited.
    Show Others
    All classes/layers display normally, except for those set to invisible or grayed; even though visible, objects in classes/layers other than the active class/layer are not editable and cannot be snapped to
    Show/Snap Others
    All classes/layers display normally, except for those set to invisible or grayed; objects in any normally displayed or gray class/layer can be snapped to. Only objects in the active class/layer can be edited.
    Show/Snap/Modify Others
    All classes/layers display normally, except for those set to invisible or grayed. Objects in any normally displayed or gray class/layer can be snapped to; only objects in normally displayed classes/layers can be edited. (An object on another layer can only be edited if its layer scale and view are the same as those of the active layer.) Locked objects display with gray highlighting.
  3. The current class or design layer display changes accordingly.
Setting Visibilities in the Organization Dialog Box
The Visibility Tool
vectorworks.net
